I'm trying to capture a UK djs old radio shows, the one with snoop dogg but cant find a way to do, never tried before
http://www.timwestwood.com/westwood%20interface.html
hit radio
classic westwood shows
then the snoop link
How do i save it so i can keep it, listen to it its a wicked show![]()
Results 1 to 9 of 9
We're Bought and Sold
For English Gold. -
Is it a video or audio stream? There are tons of apps out there for saving streams.
It's a stream-i think-it just plays when you hit the link it dont ask to save or anything.
For English Gold. -
Download Audacity. Open it, then set it to the WAVE OUT or STEREO in the pull down box.
Press the RECORD button. Then press the play button on the radio website.
You should see it start to record. Listen to the whole program, then go to audacity and press STOP, then choose FILE >> EXPORT AS MP3.
Fo shizzle, ma nizzle. -
High 5 there bro....is that shot of Audacity the actual shot of it recording that snoop show? just so as i can go by it for reference...thanks
did u listen to it? i'm going to see him on the 4th for the third time, saw my man back in 96 then a few months ago...We're Bought and Sold
For English Gold. -
the one i downloaded dont have WAVE OUT or STEREO should i set it to WAVE/MP3?
For English Gold. -
I use this:
http://www.nowsmart.com/arwizard/
It isn't free (but there is a trial version that lets you record up to 3 minutes), but it records anything heard from your soundcard to WAV. or MP3.Cole -
Have not tried Audacity for that. I do know that Total Recorder will do the trick and it's only like $12. But maybe try Audacity first if you can get it to work for free so much the better!
Good Luck
RogThere are many ways to measure success. You just have to find your own yardstick. -
For free - http://www.replay-video.com/freecorder/index.php (it will save in mp3 format and for only half an hour at a time but its free)
Internet radio player?
By AlanHK in forum Software PlayingReplies: 2Last Post: 22nd Jan 2011, 07:31 -
Need Help: Ability to record FM Radio And TV Channels at once.
By ginetti in forum MediaReplies: 5Last Post: 1st Dec 2009, 18:46 -
Car radio fault
By didikai in forum Off topicReplies: 2Last Post: 26th Oct 2008, 17:17 -
Do you listen to Sports Talk radio?
By yoda313 in forum PollsReplies: 18Last Post: 27th Feb 2008, 10:11 -
Can't launch online radio from Firefox
By daamon in forum ComputerReplies: 4Last Post: 20th Jul 2007, 20:22
