what can i do to stop my router from quitting on me. I say my router because after a long period of time i will log off of certain programs i use on the internet, so i will just have to start the program again, but thats a paind sometimes cause im downloading constantly. is it my processor not working fast enough, is it my physical internet cable connection, or since i download so much should i be load sharing?....holla back
Results 1 to 9 of 9
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
a linksys 4 port router and switch
What model and version?
If you have a WRT54G you could try upgrating the firmware to version 3.03.9. For more info check this link: http://wrt54g.com/forum/viewtopic.php?t=170
Sometimes disconection problems are not caused by the router itself but by the network card. Please also write down the detials of your card. -
cool, will do
Make sure that you have the right model. If you flash your router with the wrong firmware you may destroy it.
If you do not have the router model I was talking about, check the following linck for other downloads: http://www.wrt54g.com/pages.php?p=firmware and http://www.linksysinfo.org/modules.php?name=Topics
For disconnections caused by the network adapter check these links: https://www.videohelp.com/forum/viewtopic.php?t=263826
Probably the example is for a different network adapter, but the basic Windows configuration should be the same. -
I was also going to recommend upgrading the firmware.
I had more or less the same problem with my Netgear router. Mine kept disconneting from the internet, a firmware upgrade seemed to solve the problem. -
weill i just installed a new network card for eveything to run through, that di n' seem to solve the problem, maybe ill go with the firmware upgrade later on....ill get back to yall
There are newer fimware for some Linksys routers. You could try them.
Getting A New Router
By Tom Saurus in forum ComputerReplies: 17Last Post: 11th Nov 2011, 16:42 -
Need a new Router.
By Poppa_Meth in forum ComputerReplies: 10Last Post: 29th Sep 2008, 05:50 -
Linksys WRT54GX4 router problem
By SIRCOOKS in forum ComputerReplies: 9Last Post: 19th Feb 2008, 10:40 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
Connection problem with Asus router
By tweedledee in forum ComputerReplies: 23Last Post: 3rd Sep 2007, 22:07
