Amigos, as placas Pixelview indicam a quantidade de bit capturados por pixel, as antigas com 8 bit e a mpeg com 10 bit de profundidade de captura. As outras placas do mercado não indicam nada, Pinnacle, ATI etc...
Alguem pode me orientar como comprovar estes bit de captura em uma placa, existe algum software que indique isto ??
agradeço atençao
rebrasil
Friends, the Pixelview plates indicate the amount of bit captured by pixel, old with 8 bit and the MPEG with 10 bit of depth of capture. The other plates of the market do not indicate nothing, Pinnacle, ATI etc... Alguem can guide me as to prove this bit of capture in a plate, some software exists that indicates this? I thank atençao rebrasil
try to use on line translation and post in english please
tente usar-se por favor na tradução e no borne da linha em inglês"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I think he's asking about DC8, DC9, DC10. Most of this information is actually found on the box of the devices. Most software defaults to DC8 while most hardware defaults to DC10.
In the end, from home sources, it usually doesn't make that big a difference.Want my help? Ask here! (not via PM!)
Thanks moderator.
Friends, the Pixelview capture cards indicate the amount of bit captured by pixel, old with 8 bit and the MPEG with 10 bit of depth of capture. The other capture cards of the market do not indicate nothing, Pinnacle, ATI etc... Somebody can guide me as to prove this bit of capture in a capture card, some software exists that indicates this? thanks regards rebrasil -
all home mpeg cards capture 8 bit color depth ..
you may be confused by DC8, DC9, DC10 which is not color depth ..
It is DC component precision"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Not confused between the two, only confused to what he means.
DVD recorders mostly do 10-bit, that's what I was referring to by hardware. Most capture cards are software controlled anyway.Want my help? Ask here! (not via PM!)
when i said "you" , i meant rebrasil was confused
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
