Hi there,
This is my first DVD Project. I used D.I.K.O., AVICodec and DVD-LAB PRO.
I download the original files (*.avi) with emule, separated audio and video with DIKO (following the instructions from https://www.videohelp.com/forum/viewtopic.php?t=263309 ) into *.mpv and *.mp2 files. After creating the menus I compiled the project, but found out the audio must be delayed (voices come up much before the actual lips moving). I dont know, however, how many "ms". Because I dont want to try a bizillion times before I actually get it right, I ask you for help.
Is there an easier way of matching sound and picture (or an easy way of finding out the "ms"?
Here is my File Overview of Project
Charmed.dal
VMG Menus:
VTS 1
Menus: Menu 1, Menu 3, Menu 5, Menu 6, Menu 7, Menu 1/Menu 3
Movie 1: MPV 720x576,25.00,4:3,00:51:16,PAL,720 kbps
Audio 1: MP2 48.0 kHz,192 Kbps,00:42:46,Joint_stereo,192 kbps
Subtitles: 1
Movie 2: MPV 720x576,25.00,4:3,00:51:11,PAL,720 kbps
Audio 1: MP2 48.0 kHz,192 Kbps,00:42:42,Joint_stereo,192 kbps
Subtitles: 1
Subtitles: 1
Movie 3: MPV 720x576,25.00,4:3,00:51:42,PAL,720 kbps
Audio 1: MP2 48.0 kHz,192 Kbps,00:43:08,Joint_stereo,192 kbps
Subtitles: 1
Subtitles: 1
Movie 4: MPV 720x576,25.00,4:3,00:51:59,PAL,720 kbps
Audio 1: MP2 48.0 kHz,192 Kbps,00:43:21,Joint_stereo,192 kbps
Subtitles: 1
Subtitles: 1
Movie 5: MPV 720x576,25.00,4:3,00:51:56,PAL,720 kbps
Audio 1: MP2 48.0 kHz,192 Kbps,00:43:20,Joint_stereo,192 kbps
Subtitles: 1
Subtitles: 1
Movie 6: MPV 720x576,25.00,4:3,00:50:54,PAL,720 kbps
Audio 1: MP2 48.0 kHz,192 Kbps,00:42:27,Joint_stereo,192 kbps
Subtitles: 1
Thank you all in advance!
ps: please bear in mind that my first language isn't English. So, take it easy on slangs and technical terms.
Pthree
Thank you guys for the tips. I actually did something different. I started it all from scratch and miraculously nothing went wrong. The sound was in synch!!
I appreciate all the help and must say this is the best site for dvd projects on the web. However, there is something else I'd like to ask:
I got the charmed theme song and wish to use it in my menus, but all I can do is link the song to each separated menu. I.e., every time I change menus the song starts all over again. I wish it would keep playing till the end and only then restart, regardless of what menu I change to.
Is it possible to do so? How? Just so you know I use DVD LAB PRO 1.53.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
