Results 1 to 14 of 14
  1. i have been tring to rip the jacket and can not get it to work.
    i have used dvd decrypter shirnk and vobblanker with no luck.
    with shrink i get to 99% in anilize and it shuts done.
    in decrpt it says it is encrypted wick is strange and will not finish movie.
    any help would be great
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    ensure you are using the latest version of dvd decrypter which is 3.5.4.0
    Alternatively, try DVDFab Decrypter.
  3. thanks but that did not work ethir
    dvd shrink keeps telling me it can not find the folder
    and dvd decrypter keeps telling me it is encrupted with css\cppm
    so i have no clue thanks
  4. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    dvd decrypter should rip encrypted discs. if you've tried most rippers, then the only other possibility I can mention is that the disc may be faulty/damaged.
    Does the dvd play flawlessly in your PC?
  5. Banned
    Aug 2002
    beautiful
    that is exactly what dvddecrypter does - decrypts css/cppm encrypted files on dvd discs.
    are you sure you haven't uncheck decryption within dvddecrypter's options?
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    You cannot uncheck decryption within dvd decrypter's option. The dvd will decrypt under all circumstances. thats the whole point of encryption, to prevent copying.
  7. yes it played fine. and dvd decypter tells me that this is strange that this is encrypted. so i really have no clue i got the files on my hard drive and can not get them in to shrink to compress to get to dvdr so thanks for the help
  8. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    does the dvd have any other copy protections like sony's arrcoss protection?
    Did you try DVDFab Decrypter?
  9. If you are refering to the JACKET_P folder on a DVD then you do not need to decrypt it. The JACKET_P folder is not encrypted. All you have to to do is right click the folder and copy then go to where you want it on your HDD and right click and paste.
    There is nothing illegal, until you get caught!
  10. yes i tryed fab and it worked but know i can not get to open in shrink to get it to fit on a dvd it says can not find vtbs. i'm talking about the movie that is called the jacket
  11. Region 1 ripped just fine with last (now longer latest) dvd decrypter
    Originally Posted by jagabo
  12. Banned
    Aug 2002
    beautiful
    ever seen its settings at all?
    :P
  13. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    How did I ever miss that?
  14. Donno what the problem is or if you're still having it or not, but I've succesfully backed up this movie myself with Decryptor and it went fine. I actually watched my copy the first time I viewed it, perfection.
