Hello once again,
I tried googling it and found a few programs but dont know which ones are any good.
Anyone know of a reliable "real time" program that tells CPU, case, etc, etc heat?
Lemme know.
LG
There maybe an utility provided with your motherboard. Check your motherboard installation CD.
Other than that, if you want "real time", you're looking at hardware. A fan controller which monitors both temperatures and controls the fan speed accordingly. -
Motherboard Monitor is one of the most used. One site: http://www.pcworld.com/downloads/file_description/0,fid,7309,00.asp Not all motherboards will work, but give it a try. It depends on the MB sensors. MB Monitor will read fan speeds also, if they have the feedback lead.
Looks pretty good Roz. I have downloaded it and will install later on.Originally Posted by Roz
Thanks .. appreciate it
LG
CPU Temp Erratic and High in BIOS?
By bevills1 in forum ComputerReplies: 3Last Post: 7th Jul 2011, 11:09 -
CPU temp "alert"
By Edgarke16 in forum ComputerReplies: 2Last Post: 20th Feb 2011, 17:44 -
CPU Temp.
By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 13:21 -
Standalone CPU Temp Monitoring App
By Soopafresh in forum ComputerReplies: 8Last Post: 17th Mar 2008, 01:51 -
CPU Temp
By Willy5157 in forum ComputerReplies: 4Last Post: 9th Feb 2008, 20:22
