I made up a DVD for someone and believed it was error free and everything but the feedback was this one program I made had a picture that intermittently flickered on and off as it played. The soundtrack is fine. I may have used the Quicktime Pro trick to make it 4:3 letterbox before encoding as it was 640x352 pixels.
I don't have info on the DVD player being used.
It was encoded pro DVD via Squeeze and DVDSP mounted. The only thing I can think where I went wrong was maybe the file was Progressive Scan and it's being played on a DVD player that doesn't recognize that.
Q: Can a progressive scan video be played okay on non-progressive scan DVD players? Should interlaced (bottom fleld first, for example) only be used? This is the only thing I can think that may have created playback problems.
Thanks in advance.
Results 1 to 1 of 1
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
Having Strange Problem with after encode!
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 20th Mar 2011, 04:36 -
Little Problem during encode in Format Factory
By Stef2010 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 10:43 -
Problem with Independence Day (Region A) encode
By meatycheesyboy in forum Blu-ray RippingReplies: 2Last Post: 2nd Sep 2008, 12:07 -
NEW PROBLEM: Will Not Encode
By totalnewbiedumbass in forum ffmpegX general discussionReplies: 4Last Post: 14th Dec 2007, 10:25
