Will you be adding a Mpeg4 to DVD conversion in future releases maybe? Just curious.... :P
Results 1 to 10 of 10
Mpeg4 is already supported. xvid for example.
The file I have must be a differnt type then, because it doesn't "see" it when I load SVCD. Thanks..
what is the extension of the file?
change it to .avi and try again.
Did it load as an asset?
No sir. It doesn't see it when I try to load it as an asset, thats the issue for me so far. It must be a different type of AVI file. I go to add it as an asset in SVCD, but it doesn't show it so I can load it. I sent you a PM with a sample of what it is...
I have had no problem loading and converting mpeg 4 files. I would suggest that you make sure that you have the proper codec loaded that supports the mpeg 4 files. I personnally use one that is no longer available since it is now part of another program.
You can get it here:
HDV .m2t footage - Best quality conversion to MPEG4- method/tools
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 01:30 -
MPEG2 to MPEG4 conversion
By altavistasf in forum EditingReplies: 2Last Post: 11th Jun 2010, 23:35 -
Solutions for DTV conversion day ... someday in the future
By lacywest in forum DVB / IPTVReplies: 2Last Post: 28th Jan 2009, 12:28 -
Looking for answers/thots on conversion: most future-proof format/method
By yvonney in forum Video ConversionReplies: 12Last Post: 5th Apr 2008, 03:33 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 16:56
