I've problem converting vcd dat files to .wav. I've all the tools that are nescessary to do this, but this individual vcd won't allow me to do it. This vcd is playing fine on a standalone dvd player, but I can't play it on the computer cd rom such WMP and other software vcd players? If it contains bad, or corrupted files, how come the standalone dvd players can play it? My process of converting dat audio files to wav files are like this, copy all dat files from an original vcd to a temporary folders, then used vcdgear to convert from dat files to mpeg files, and final, I used virtualdub to open up the mpeg files which enable me to save it as wave files. But this vcd won't even allow me to copy dat files to temp folder, it says invalid DOS..OS... What is up with that, does anyone have any ideas??? :?:
Bad/corrupted--MPEG video is written onto VCD's such that if there is corruption, it'll still play reasonable well. Hardware players seek via the underlying tracks/sectors/Min:Sec:Fr. Software players seek mainly via the filesystem--with corruption, they wil have a hard time.Originally Posted by JonPumin
DON'T just copy the files. Extract/Rip them correctly and directly, either via VCDGear (.DAT->MPEG), VCDEasy (VCDxRip tool), or ISOBuster (Extract RAW-but convert M2F2 to Video).
Virtualdub sometimes doesn't extract audio correctly. Try TMPGEnc instead. Load mpg as VideoSource, [File | Output to file | WAVE file].
HTH,
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 08:26 -
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
Avisynth script problem (aac to wav conversion)
By greggery in forum Video ConversionReplies: 0Last Post: 22nd Nov 2007, 11:59
