I just purchased QT7 Pro. However for MPEG Streamer it says I need the MPEG2 encoding software that comes with QT6 Pro. However, since I just purchased QT7 PRO, shouldnt that be installed with the PRO version? Or do I have to somehow install QT6+(without overwriting QT7 Pro)?
Thank you in advance for any support
ScottZ -
QT6 doesn't come with either an MPEG2 encoder or decoder, neither does QT7. Pro or not, it's the same.
You have to buy a decoder from Apple ($29US?) to get MPEG2 decoding.
You have to do it for QT6. You have to do it AGAIN for QT7.
Apple doesn't make a simple MPEG2 encoder for QT/QTPro. It makes "Compressor" as a full-blown application. This application comes with FCP and/or DVDStudioPro, and AFAIK is not available any other way.
Here's your cost breakdown:
QT6-->QT6Pro $29
QT6 MPEG2 decoder addon $29
QT7-->QT7Pro $29
QT7 MPEG2 decoder addon $29
FCP/DVDSP ~$900
Can't get around this any other way (legally, of course).
Sorry,
Scott -
That's right. Sorry-going on memory and assumed the Pro upgrade was same cost as MPEG2 upgrade...
It's Friday!
Scott -
IF you own the one bought with QT 6, you can use it with
QT 7 Pro. Just re-install it from your SAVED downloaded
.dmg file.
http://discussions.info.apple.com/webx?7@998.r4j0aXn5SI4.4@.68b2f68e/3
you did save it right?
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I dont remember, its been so long...but thank you all for the help. Hopeuflly I wont have to purchase it again(which i wont do anyways)
ScottZ
MPEG2 to H.264 Conversion question
By tonyaldr in forum Video ConversionReplies: 19Last Post: 5th Apr 2012, 08:06 -
Strange Mpeg2 Conversion Question
By mohawkcr in forum Video ConversionReplies: 1Last Post: 5th May 2010, 20:34 -
mpeg2 to mpeg2 conversion
By asdfen in forum Video ConversionReplies: 9Last Post: 4th Oct 2009, 13:45 -
mpeg2 bitrate conversion
By sandiegoguy in forum MacReplies: 6Last Post: 16th Aug 2009, 03:40 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
