  1. Hi,
    When I rip a DVD and confert it to a VCD with subtitels, the subtitels got all blurry, I Use Flaskmpeg with the Panasonic Codec. How can I get clear subtitels using these tools?
  2. that depends on what version of flask U use, flask & panasonic are a damn sight better than Tmpeg for converting. Try the newer version of flask06 + the subtitle fix this should hopefully cure it!!
    (u could always try dvdx it seems to work ok aswell)
    Kev!
