Are these two pc's created equal ? I've never owned a laptop, but like it's convenience.
Coffee makes you happy.....Except when it messes you up
Laptops are generally more expensive for the same spec of PC, limited upgradability and designed for portability.
Also, laptops can never really be as fast as an equivilent PC. Lappy HDDs are way slower than Desktop 3.5'' ones, their processors like to throttle themselves all the time to save on battery power, and 99.9% of them have un-upgradeable JUNK for graphics. I suggest just getting a nice Desktop for home and a cheap lappy for the road. You'll thank yourself later...
Your base? Well, they belong to me now... -
Hi,
You can get a "desktop replacement" laptop with near full power of a desktop. BUT they weigh like 10 pounds or something. Really cuts down on the portability factor.
But I agree with the above statements. Laptops are nice for go anywhere power but not as customizable as a desktop. You can get the parts for laptops but they'll more expensive in general.
About the only upgrades to the laptop, except maxing out memory, and getting a larger HD replacement, involve adding external peripherals. This defeats the purpose of the laptop. I agree with Studtrooper, get a cheap laptop for mobile, and stick with the desktop for home use. Remember, your laptop can be broken or stolen easily, so remember to backup constantly. I would also recommend the purchase a cable lock, if you constantly use it outside the home.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
Integrate HDTV/Desktop/Laptop Wirelessly?
By Kravage in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2010, 15:19 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
Moving a Project from a Desktop to a Laptop?
By solarblast in forum Newbie / General discussionsReplies: 6Last Post: 28th Oct 2008, 23:47 -
Video Editing: Desktop vs Laptop
By Jedi5 in forum ComputerReplies: 11Last Post: 9th May 2008, 20:26 -
DVDFab Platinum - desktop vs laptop speed
By C8175W in forum Authoring (DVD)Replies: 6Last Post: 30th Dec 2007, 16:54
