Hi all...
I have a .dat file that I would like to turn into a vcd so that I can watch it on my standalone Phillips 710.
Any suggestions would be welcome.
(be gentle on a newbie pls !!)
PS-Merry Xmas !
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
some times U can just drop it straight into Nero & burn it as a compliant VCD if it wont do that then download Tmpeg. Use the simple multiplex option on the tools section making sure U have selected vcd-mpeg 1 in the check box & away U go its done & U can burn it as a VCD!
Kev! -
I've never had a problem with dropping the dat right into nero, but if not, renaming the extender from dat to mpg will work too.
Ok-cheers.
If I rename it from .dat to .mpg, will I be able to drop it straight into my standalone DVD player & watch it on my tv then ?
Cheers again.
Hmmm-I have just used Nero, but all I ended up with was a set of folders called CDI, EXT, MPEGAV, SEGMENT, & VCD.
Is that right ??
I assumed that I would end up withy a file on my cd that I could just drop into my standalone DVD player ?
Thanks again.
It's correct, those are the folders the DVD needs to know how to read your VCD.
Brilliant-just dropped into my standalone & I'm watching it now !!
Thanks to all for your help.
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
Need VCD DAT video splitter Without Reconversion?
By kitharass in forum EditingReplies: 7Last Post: 16th Feb 2010, 13:37 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50
