On rare occasions when backing up one of my DVDs the following happens...
I use Fast DVD Copy with my Mini Mac.
The original plays fine in my DVD player, Xbox, and Mac.
The backup copy...
-Gets error message in DVD player "wrong region"
-Xbox gives message that it's got parental controls, I must choose "Yes" before I can play the movie...but it plays.
-Mac plays movie fine.
Any ideas![]()
You might want to try some different software. I know that you are used to what you use, but there are better ways to go about it.
Usually I use Mac the Ripper(you can find @ www.versiontracker.com). Then from there I use DVD2ONEX(dont know if I had to pay for it or not cant remember, its cheap and worth it either way). From DVD2ONEX it sizes it down AND can make an image for you, in which you can burn that image using DISK UTILITY(as found under, APPLICATIONS>UTILITIES>DISK Utility...Thanks
ScottZ -
Originally Posted by FatFreeVW
It's 50 Euros, which doesn't seem particularly cheap. It's more expensive than all of its competitors. On the other hand a lot of people (myself included) think it's the best. -
What about copy protected DVDs...does this software have any problems with that?
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
You misunderstand me.
1st. Yes I own all dvd's I back up.
My backup software was working great...then I did 2 things.
1. After having a problem with my iPod Apple had me reset my mac by holding the power button while it booted up (or something...I'm fussy now).
2. Upgraded to Tiger
Now my DVD burner thinks all backups are for someone in China. There has to be a way to reset my DVD's Region setting which is now set to the region where mini mac's are made. -
Sorry...didn't see this move up...thought it was many pages down so I created a new topic.
Take an orignal, factory DVD you own, stick it in
the DVD drive, and launch DVD player.
DVD Player, if it has been re-set like you say,
should prompt you to re-set the region to
the region 1. Click ok, and the drive will be
set to region 1.
then, eject the factory dvd, then insert a backup.
What happens then?"Everyone has to learn, so that they can one day teach."
Urban Mac User
More weird conversion results
By carlmart in forum Video ConversionReplies: 21Last Post: 23rd Jun 2009, 06:40 -
Weird conversion results
By carlmart in forum Video ConversionReplies: 47Last Post: 11th Jun 2009, 09:51 -
AVI to DVD results in weird playback fault
By JustGreg in forum Video ConversionReplies: 0Last Post: 26th May 2008, 09:51 -
My results from blu ray backup and Encode/transcode
By ultraman36 in forum DVD RippingReplies: 8Last Post: 19th Dec 2007, 16:21 -
Watching videos on my computer results in weird pixelation and blurring
By dan1230 in forum Newbie / General discussionsReplies: 9Last Post: 4th May 2007, 11:46
