Hello,
I think I already know the answer to this question, but to be sure, here I am.
When using a KVM switch, do you HAVE to use all 3 inputs (ie. mouse, kb, and monitor)? Or can you pick and choose?
Why? I obviously have two computers and one monitor, hence the kvm switch. I want to use my wireless keyboard and monitor for both. For the mouse, I have my wireless optical mouse that I use more often but its usb and not PS2. I have a spare mouse which is PS2. Can I plug the PS2 mouse into the tower that I would use less often and plug the usb mouse into the tower I use more often, then use the KVM switch to go back and forth, using whichever mouse is appropriate?
I would think the answer is yes but just making sure.
Thanks in advance.
LG
Yes. Or you can get a KVM that has USB hookups if both your keyboard and mouse are USB.
FB-DIMM are the real cause of global warming -
Well, I got this KVM for free so why not use it.
I bought a cheap wireless kb and mouse combo a year ago. They are both PS2 but the mouse has a rollerball and I hate it.
I have a spare USB mouse that I want to use on the PC I use more often (my surfing/processing computer) and then slap the rollercrap on the other PC (encoding and downloading).
Hence the question
But thanks a bunch Rally. I figured I could do it. One mouse hook up has nothing to do with the other if I am bypassing the KVM. Just wanted to be sure.
I appreciate the time.
LG
I need KVM switch help, re: DVI and D-Sub cards..
By sdsumike619 in forum ComputerReplies: 4Last Post: 14th Dec 2010, 23:51 -
Recommend a good USB 4 port KVM
By kenmo in forum ComputerReplies: 2Last Post: 29th Jul 2010, 11:57 -
KVM question
By gsh in forum ComputerReplies: 7Last Post: 28th Jan 2008, 14:25 -
Monitor split for high resolutions? (KVM)
By lordsmurf in forum ComputerReplies: 9Last Post: 5th Dec 2007, 15:30 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23
