I have Tmpgenc + AC 3 plug in but when I encode movie with AC3 audio the output (mpeg2) have noisy sounds or it doesn't have any sound .
Could somebody please tell how can I know if the AC3 plug-in worked ?
If the plug-in doesn't work ,please tell me how can I make it work ?
Any suggestion would be very appreciated![]()
if you are making dvd just use the ac3 from the avi. convert as usual. demux/split the ac3 from the avi with virtualdubmod. add the mpg in tmpgenc dvd author and select the ac3 as audio source!
if you anyway want to convert the ac3 convert it to wav and use in tmpgenc with goldwave.
or
use divxtodvd!
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
AC3 doesn't work after format
By Xavier in forum AudioReplies: 7Last Post: 26th Feb 2009, 18:27 -
How to encoder file with AAC/AC3 in TMPGEnc Xpress 4 (English version)
By roc255 in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 16:57 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
