Hi all,
I've got some widescreen xvids that I'm currently in the process of converting to DVD.
I'm using DIKO to convert them and on the video tab in configuration I select, "Encode Anamorphic" as I want to watch them on a widescreen television.
Most of my files have worked fine, but some of them, just won't encode properly in anamorphic. It seems all my files with a resolution of 608x336 convert fine and turn out perfect, but my files with a resolution of 624x352 come out wrong.
Can anyone offer any advice? When I encode the 608x336 files, DIKO sends an aspect ratio of 16:9 to FreeEnc but with the others it tells them they are 4:3. I've even tried converting with FreeEnc and forcing 16:9 but they turn out 4:3 anyway.
Maybe if I change the resolution of the files down to 608x336? But is there a simple way to do that?
Thanks for the help.
you could manually set it to 16:9 with dvdpatcher after converted.
and visit http://www.vmesquita.com/forum/
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Widescreen aspect problem converting avi to dvd
By spiritgumm in forum Video ConversionReplies: 8Last Post: 10th Apr 2010, 14:14 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 18:01 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57
