I am getting very mad at a situation i am having. I hasve burned dozens of dvd's but for some reason 3 of them that were encoded, burned, etc. the same way will not play in my dvd player but the others do. Please help. hit me up if you need more info from me to help out.
Each One Teach One
Please post back the following info,
we will be glad to help.
1. On the 3 dvds that do not work, what brand of discs are they?
2. On the 3 dvds that do not work, what are the types of movies that are on them? commerical movie backups or
self created ( vacation type) home movies?
3. What brand of DVD Player do you have?
4. What tools are you using to accomplish this?
(types and names of software, hardware, etc.)
Once we have this information, we can start troubleshooting."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
ok here we go.
1. The discs that i am using are ritek's. The same ones i use for everything else.
2.On the movies burned they were avi.'s that were encoded with ffmpegx.
3.I have a Panasonic DVD RV-32
4.I am using ffmpegx to encode, popcorn to burn. But i also have other software. I have dvd2one, toast, mpeg2 works demo & MTR.Each One Teach One -
Urban Mac User -
When this happens, my suspicion is always that ffmpeg was used to encode. ie, the DVD ffmpeg option was selected in FFMPEGX
ffmpeg is not a truly constant bitrate encoder and can lead to certain players not playing the DVDs correctly. mpeg2enc on the other hand is truly constant. Some movies lead to more variation in the bitrate so this problem does not show up in all cases.
The 2 options are to either re-encode using mpeg2enc, or to author your original mpegs, or now vobs, with Toast 6.1.1. This Toast option is not 100% guaranteed, but it is faster and is my main method of converting to DVD. Toast since 6.0.9 makes en effort to standardise mpeg streams by padding them.
If however you did use mpeg2enc to begin with then I'm stumped.
Alph -
Each One Teach One
Playing .mov on DVD player
By gkp_pc in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Jun 2011, 23:04 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
playing files on a dvd player
By rigger1972 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 13:23 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49
