I am having trouble eliminating hiss from the audio when I capture video.
I am using MMC 7.5 (Set to full DVD capture) a built in C-Media audio card on an AMD 1600+ system. No matter what adjustments I make to audio levels or capture format the hiss is always there.
On my previous set up I did not have any problems with hiss.
Is anyone else having the same problem and know what is causing it?
I have also just noticed that if I de-multiplex the MPEG(1 or 2), amend the sound streem so the hiss disappears and then re-multiplex - the hiss re-appears on the re-multiplex.
I did post this in the capture section but since discovering this last point I think it is probably more relevant here !
Help !!!!
I have a similar problem.
I have a MPEG-2 video stream (.m2v) and a .mp2 Audio Stream (44,1 kHz, 224 kbps)
When I play the audio stream with an audio player (e.g. Winamp), it's ok.
But after multiplexing video and audio to a SVCD compatible MPEG with TMPEG or bbMPEG, the resulting mpg-File hisses when played in PowerVCR.
What am I doing wrong? -
Found a forum thread that might be interesting:
www.dvdrhelp.com/phpBB/viewtopic.php?topic=70243&forum=11
Audio Hiss Problem--I tried audacity
By bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 08:55 -
Audio hiss removal in VirtualDub
By BobAchgill in forum Newbie / General discussionsReplies: 6Last Post: 27th Apr 2009, 08:57 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 07:08 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jul 2007, 23:03
