How i creat 2-3 vcd in a single DVD which compatible in standaloan DVD player.
Can i select from menu which i want to play?
Do i need to convert MPEG1 to MPEG 2 before burn?
which is more compatible mpeg2 programe streem or MPEG2 split streem (separate Audio & video) format to burn in DVD?
Little Baby
This thread may be useful:
https://www.videohelp.com/forum/viewtopic.php?t=129786 -
transfer the vcd's to your HDD converting them to mpeg 1 with vcdgearOriginally Posted by diginode
And load into TMPGEnc DVD Author
Yes. see #1Originally Posted by diginode
No. see #1Originally Posted by diginode
But the player you play it on still must support playback of the vcd format even though it is authored and burned as a dvd.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
