For all of those who are trying to decide if a standalone DVD recorder is the best way to save all of their old analog tapes, I thought I'd share my experience.
The first method I tried was:
analog tape>HollywoodDVbridge>Mac(iMovie)>DVD(iDVD)
This method worked, but color and sharpness were noticably decreased from the original. The biggest problem was dropped frames on old, stretched tapes.
The next method I tried was:
analog tape>CanonZR60pass-thru>Mac(iMovie)>DVD(iDVD)
The sharpness was better, but overall gave similar results as the Hollywood DV Bridge. Dropped frame problems could be somewhat (not completely) eliminated by taping to MiniDV prior to transfer to Mac.
The next method I used was:
analog tape>Canopus ADVC300>Mac(iMovie)>DVD(iDVD)
Great color, sharpness, contrast, and dynamic range. No dropped frames. I used this method for all of my home tapes (that were decent quality). This is still my preferred method for good source material. However, when transferring poor quality tapes for other people (e.g., 14 year old EP VHS, some possibly 2nd. gen dupes), this method ran into a problem where background detail and trees ended up looking like impressionistic paintings...with so little detail and color to begin with, the double conversion - analog>DV and DV>MPEG2 - caused the compression artifacts to overpower the picture details.
analog tape>standalone DVD recorder(Lite-On LVW-5006) via S-video
For all analog source material, the DVDs had less color, contrast, and dynamic range when compared to either the tape output or the Mac/iDVD output in a side-by-side comparison. However, the DVDs still looked great and were very watchable. If I had not done the side-by-side comparisons, I probably wouldn't have noticed the lack of color (mostly loss of saturation) and contrast (and if I did, I would have ascribed it to the old tape medium).
The LSI-chip in the LVW-5006 does a fantastic job of retaining what little detail there is on old tapes, especially the old EP tapes that caused problems with the Mac encoded DVDs.
This is my preferred method for poor source material. If I wasn't already spoiled by the great menus and the editing available from Mac-based conversion, I could have been happy with the LVW-5006 for all of my old tapes.
Since the Lite-On LVW-5006 includes a FW input port, the last method I tried was:
analog tape>Canopus ADVC300>Mac(iMovie)>standalone DVD recorder(Lite-On LVW-5006) via FireWire
This produced similar results to the iDVD encoded DVDs in terms of quality and color saturation, but lacked the nice iDVD menus. The only upside was the realtime encoding vs. the overnight encoding on the Mac (although one possible advantage is the the LVW-5006 has a 3-hour recording mode that might produce usable results...I haven't tried it yet).
Both the Mac(iMovie/iDVD) and the standalone DVD recorder can produce excellent quality MPEG2 video with good source material. The standalone produces more watchable video from poor source material with difficult to encode details like foliage or high motion. For a poor quality "talking head" video, the Mac/ADVC300 will produce better color (saturation) and contrast (tonal range). It will also have no dropped frames.
The Dolby audio from the standalone is slightly better than the MPEG audio encoded by iDVD.
For those who don't want/need to edit their video, the biggest downfall of the standalone Lite-on LVW-5006 is the lack of good menu and chapter options. Editing is linear - by pause and record buttons - and really is not a usable option on the LVW-5006.
Summary
Mac
Pros - editing in iMovie, iDVD menus, easier to make multiple DVDs, good quality up to two hours with maximized bitrate, and better color and contrast (w/ ADVC300).
Cons - loss of some types of detail due to double compression (DV & MPEG2), longer encoding times, limited to DVD blanks supported by your Mac drive, can't use Mac during capture (and fills HDD), expensive single-purpose hardware (ADVC300).
Lite-On LVW-5006
Pros - real-time encoding, frees up your computer, good quality 1hr and 2hr modes (as well as available 3, 4, and 6hr modes), can use as "VCR", FW input (from Mac or MiniDV camera), single compression (MPEG2) keeps certain details, can use any single layer DVD media, good Dolby audio, can make SVCD and VCDs (not sure if this is a pro or con).
Cons - poor (no) editing, poor (no) DVD menu, compatibility with media and DVD players not as good as my Mac, some loss of color saturation and tonal range (as compared to the ADVC300), recording modes are fixed so you cannot maximize the bitrate, and you need to "trick" the unit to accept DV input from a computer.
Hope this "review" helps.
Macrovision Firmware Lite-on LVW-5006
By drewbert73 in forum DVD & Blu-ray RecordersReplies: 36Last Post: 9th Sep 2012, 12:05 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
VHS to DVD w/o going through computer or if computer Roxio VHS -DVD?
By xxnonamexx in forum Capturing and VCRReplies: 5Last Post: 12th May 2010, 21:19 -
Standalone recorded DVD playing in a Mac problem
By tigerdad in forum MacReplies: 4Last Post: 5th Aug 2008, 21:28 -
Computer DVD players vs standalone
By JudgeGarth in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2007, 12:00
