How can i disable if a want the video to be played from codecs that i've already installed?
As for the audio decoder,how can it be enabled every time a video file is playing?
Also can i set an audio delay?
Yes but is there a way to disable it at once,and not one codec at a time?
Well you could unregister it or set it to a lower merit so that it won't get used unless it is the only decoder available.
Damn it i know all of a sudden have a problem with ffdshow,when it's enabled i can't see a thing.It's like a grey layer is covering the whole screen.
I un-installed and reinstalled it and same thing,tried all sorts of version even the very last the 19th,and same thing happens,any ideas?
Force FFDSHOW?
By therock003 in forum Software PlayingReplies: 6Last Post: 25th Feb 2012, 13:24 -
BD-RE and ffdshow
By ttheb1 in forum Blu-ray RippingReplies: 12Last Post: 29th Jan 2011, 23:10 -
What is FFDshow?
By terrypin in forum DVD RippingReplies: 11Last Post: 7th Apr 2010, 17:26 -
using ffdshow with??
By uglijimus in forum Video ConversionReplies: 7Last Post: 18th Aug 2009, 23:55 -
What is ffdshow and should I be using it?
By Hank Kinsley in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2007, 00:52
