It's rather odd, but using CCE SP I can very easily encode the HDTV.AVI files that I have, however when I try to convert a file over a certain size, the encoder just crashes at an abitrary point.
I would normally use TMPGEnc instead but for some reason, when I encode NTSC XviD AVI into a PAL DVD, the resulting disc playback is jumpy (locks up, speeds up, stops, etc).... this doesn't happen with CCE.
I have to know why CCE SP locks up when encoding files over a certain size... could it be that the movie files are not as high quality as the TV episodes?
I have made sure to keep the min, max and avg bit rates sufficently apart (at least 1000Kbps).
contact your dealer (ussually visible light) - they have good support for owners of Cinemacraft ..
Also make sure you are using the latest version from cinemacraft ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
