I have a couple xvid files encoded with AC3 sound. Right now the only software I have that will play them with sound is Nero Showtime. My problem, however, is getting these converted to DVD. Nothing I have will accomplish this because of the AC3. I thought NeroVision might be able to do this, but no sound.
I tried to extract the sound track with Vdub, but it failed.
Trial version of DVD MovieFactory also failed.
I did see the user guides on how to extract the sound, but since I really need a much better encoder and authoring program, I was considering getting TMPGenc Express and TDA with the AC3 plugin. Would this accomplish what I need to do?
TIA
TANSTAAFL
install the ac3 codec in the tools section at the left and encode the avi in the encoder of your choice , like tmpgenc
demux the ac3 w/ virtualdub - guides to the left also ..
then author the disk and burn it"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Yeah my vote for the Film Machine, particularly if you are doing PAL to NTSC conversions. It adjusts the audio flawlessly.
Or:
Demux audio (VirtualDubMod is easiest)
Encode AVI video only to DVD specs m2v with dedicated mpeg encoder (MainConcept, TMPGenc)
Feed demuxed AC3 and m2v to authoring app (TMPGEnc DVD Author). Most, if not all athoring apps take (and even prefer) elementary streams.
/Mats
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 10:32
