Hi all,
Please, does Adobe Encore use CBR, 1-pass or 2-pass VBR when it transcodes AVI files to MPEG2, fitting it on the full DVD capacity ?
This feature seems amazing cause it optimizes the bitrate, the user doesn't have to "guess" or calculate it, but I wonder if Encore, apart from calculating the optimal bitrate, uses CBR or 2-pass VBR to do the compression...![]()
I haven't found this information on the manual, neither on the help files....does anyone know it ?
Encore manual just says that it "looks for optimal quality" when doing the automatic transcode, but doesn't mention the method;
Thanks,
Zetti
i have found that the best thing to do is to choose the 4MB-7MB--or--8MB pass depending on how many clips you have inserted into the project ... 4 or less use the max possible, more than for next step down or even a 4MB pass will do to transcode your clips...
obviously a 1pass is less quality than a 2pass transcode ... hope this works for you !!! -
Thanks Ash, but the only reason for using this sw is to use its exclusive (?) "fit on media" feature, I mean, I don't have to guess the bitrate, I'd load the AVI file on it and it'd automatically calculate the optimal bitrate for me, fulling in the full disc;
Zetti
Ripping Episodes without Encore Trying to Transcode - Anyone?
By jdmba in forum DVD RippingReplies: 1Last Post: 2nd Aug 2011, 13:48 -
Transcode from High VBR to Low CBR
By AlBurk in forum Newbie / General discussionsReplies: 0Last Post: 12th Apr 2011, 03:49 -
Finished DVD in Premiere CS5 - transcode in Encore?
By Mylo in forum Authoring (DVD)Replies: 4Last Post: 23rd Feb 2011, 08:55 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
encode/transcode: Why use Encore rather than Premiere Pro?
By vid83 in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2008, 19:31
