I am having some trouble demuxing an mpeg2 video. I converted an xvid avi to an mpeg2 single mpg file. The problem is when I demux it my 23.976fps video stream always gets converted to ~29fps. Same thing happens when I tried converting the avi directly to mpeg2 elementary streams. In each case the video plays too fast and off sync with the audio. The only way it will stay synced is if I keep it as a single mpeg2 file.
Results 1 to 14 of 14
You most likely need to go into the Advanced options and tick the "3:2 pulldown" option.
it is perfectly synced when in one mpg file only when I demux it it gets off sync i dont understand why i would use 3:2 pulldown when i hover over that it says "converts 24 fps to 30fps / 60 field" i want to keep 23.976 fps. Any other suggestions?
same thing happens
here is some info gspot gives me about the file i'm trying to demux
i know it says VIDEO_FRAMES_PER_SEC = 29.970 but mpc says it plays at 23.98Code:FILE_NAME x FILE_NAME_WITH_PATH x FILE_SIZE 513,417,220 CONT_BASETYPE MPEG (.MPG/.MPEG/.VOB) CONT_SUBTYPE CONT_INTERLEAVE_TIME CONT_INTERLEAVE_PRELOAD CONT_INTERLEAVE_ALIGN CONT_TOTAL_BITRATE 1555 CONT_BYTES_MISSING CONT_AUDIO_STREAM_COUNT 1 VIDEO_CODEC_TYPE MPEG2_Video VIDEO_CODEC_NAME MPEG-2 VIDEO_CODEC_STATUS Codec(s) are Installed VIDEO_DURATION 00:44:12 VIDEO_FRAME_COUNT 79487 VIDEO_QF 0.135 VIDEO_SIZE_X 720 VIDEO_SIZE_Y 480 VIDEO_DISPLAY_SIZE_X VIDEO_DISPLAY_SIZE_Y VIDEO_ASPECT_DECIMAL VIDEO_ASPECT_FRAC VIDEO_PICS_PER_SEC 23.976 VIDEO_FRAMES_PER_SEC 29.970 VIDEO_FIELDS_PER_SEC 59.939 VIDEO_BITRATE 1400 VIDEO_MPEG4 VIDEO_MPEG4_BVOP VIDEO_MPEG4_NVOP VIDEO_MPEG4_QPEL VIDEO_MPEG4_GMC VIDEO_H264 VIDEO_SAR VIDEO_DAR 1.333 VIDEO_MPEG2 MPEG-2 VIDEO_MPEG2_I_L I/L VIDEO_MPEG2_PROG VIDEO_MPEG2_TFF VIDEO_MPEG2_BFF
Ph-h this is cause your mpeg is pulldowned. See GSpot says 23.976 pictures per sec. So MPC play it 23.976 pictures per second - it doesn't take in account the pulldown flags. The problem here is that you have desynch with the audio - this should not be.
. Hmm, how to explain better - your video has exactly so many frames as the source. Some of them have been marked with "repeat-field flag" (rff). This flag tell to settop dvd player to repeat some fields in order to display 59.939 fields per second (1 frame = 2 fields) = 29.97 frames per second total. This is the DVD and SVCD NTSC standard.
Now, you must look at the video duration to match the audio duration.
BTW, is the asynch constant or increasing?
Several questions - what (and how) you are using to play the demultiplexed file to analyse the desynch?
What are you using to look for the framerate of the demuxed file? -
I kind of understand but the problem is that when I play the demuxed files in mpc the video plays really fast and that is why the audio is not in sync with it. It looks like the frames aren't getting repeated like they are supposed to. Is there a way to fix this?
and to answer your bottom questions im using mpc for both
TMPGENC Xpress and Video Mastering Works both crash at 99% of .mkv to mpeg2
By i am x in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 09:40 -
MPEG2-TS demuxing
By fmata in forum Video Streaming DownloadingReplies: 0Last Post: 13th Dec 2011, 10:01 -
Having trouble demuxing a dvd - seems to erase some of the video?
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2009, 13:36 -
Trouble converting(demuxing)
By VJep in forum Video ConversionReplies: 5Last Post: 25th Dec 2008, 00:43 -
Video demuxing problem
By larrym in forum Newbie / General discussionsReplies: 7Last Post: 30th Aug 2008, 12:39
