  1. anybody know a software that will convert mpeg to dvd. thanks
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    It's called "authoring", check it out here.
    I hope your mpeg is DVD compliant, check out "what is DVD" on the top left to see what that means.
  3. Do you have a specific software that you recommend. Ive used ulead but it gives me to many problems.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I use TMPGEnc DVD Author, but there's dvd-lab, dvdauthorgui, IFOEdit .... just to name a few. Go to the Tools section and click on the DVD Authoring subheading for a whole heap more.
    As ZippyP. pointed out, you must make sure your MPEG is DVD-compliant before you do any authoring. If it is not DVD-compliant, then I use TMPGEnc Plus to re-encode it so it is.
    If in doubt, Google it.
  5. ok thanks ill try those softwares that you mentioned.
