  1. THE CURRENT DVD SIZE IS TOO BIG!IF YOU CONTINUE,YOU MAY NOT BE ABLE TO BURN RESULTING FILES.
    PLEASE ENSURE THAT THE VIDEO IS SET TO "AUTOMATIC COMPRESSION"OR TRY DISABLING SOME AUDIO STREAMS.
    THIS IS THE MESSAGE IM GETTING USING DVD SHRINK.HELP APPRECEIATED.
    Apr 2003
    Maryland
    My ears!!!!! Please do not shout ( CAPS )
    It means exactly what you are seeing. Your files are too large to fit. Some dvds that take up the full capacity of a DVD-9 ( dual layer ) original will in some cases not shrink to fit. I believe the max that shring can do ir around 50% compression. It would seem that it should work but some movies will still show part of it in the red zone. Movie only re-author will solve that in most cases. I mean do you really need to keep all that junk and the crappy menus they put into H Wood DVDs? Shrinking to 50% will definite not loog so good either.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    No one will help you if you shout - it's very impolite.
    That said (and assuming you are more polite next time), have you checked the compression settings ?
    Depending on the disk, Shrink cannot always get down to legal size ont he first pass. This is rare, but not unheard of. Your options are to blank out some items, reauthor as movie only, or Shrink it once, then load the results back in and shrink again.
    Read my blog here.
  4. Sorry bout the "CAPS". Thanks for the info. How do I delete the extras though?
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Look up the guides for DVD Shrink. They will reveal all (start with the guides menu to the left, or look up Shrink in the tools section for guide links).
    You should also keep this to a single post, or the mods will spank you.
    Read my blog here.
  6. Originally Posted by rocketboy
    If you want to retain functional menus, you can highlight (click) EXTRAS (left side) then select Still Image from the drop down menu on the right.
    If you just want the main movie without menus & extras, Re-author (big button up top) and drag the main movie title from the right side to the left. Either way, make sure compression is set to "Automatic."
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  7. Thanx shocker milwaukee. that worked. I appreciate it.
