I use to use older version of dvd lab pro and after it compiled i would get 2 or 3 vob files all under 1 gig each; worked great in the dvd player, however i just updated to the newest version of DLP and now i am seeing some vob files being created that are over 1gig, my question was is it suppose to be like that, or do i have to use a vob splitter to make it less than 1gig per vob. thnx guyz
If you're getting a vob over 1 gig, it's time for a bug report to mediachance.com
This is NOT supposed to happen.Cheers, Jim
My DVDLab Guides -
thnx reboot will do im kinda surprised though because it seems like im the only one having this issue since it hasnt already been fixed. weird thing is i had this proble in version 1.5 so i went back to the older version i was using then when i saw 1.5.3 i gave it a try and its still giving me 1+gig vob files
I'm still using 1.0 for that (and other) reasons.
I don't need the "toys" in the newer versions, and there's still too many bugs to work out.Cheers, Jim
My DVDLab Guides
how can I use .SUP files with DVD Lab Pro
By taasan in forum SubtitleReplies: 23Last Post: 7th Jan 2013, 08:09 -
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 06:13 -
DVD Lab Pro Transitions question
By phatk9999 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2008, 04:06 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 23:26 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 00:24
