  1. I recently upgraded a NEC 3520a dvd burner. I also have my old, Pioneer A05.
    The problem is my new NEC burner reads at a fraction of the speed of my old Pioneer. I remeber I downloaded a hacked firmware to speed up the Pioneer a long time ago. Does anyone know if there is one for this drive? I tried the newest firmware 3.04 for NEC and it is still slow.
    Thanks,
    Tony
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    check out the NEC forum at CDFREAKS.COM for some info.
  3. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Thanks,
    Tony
    If your read rate is extremely slow, you may have encountered the same problem I did recently. The fix is discussed here:
    https://www.videohelp.com/forum/viewtopic.php?p=1326423#1326423
    Apr 2004
    Miskatonic U
    Had you changed the firmware in your Pioneer in the past with something hacked ?
    When you say slow, are you talking 2x or thereabouts ?
    Most drives are speed limited for reading DVD video to discourage copying (the idea being if it takes too long, you will give up). A hacked firmware will remove the 'riplock' and give you back your speed. I suggest you did this to your pioneer at some point.
    Read my blog here.
  5. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Many dvd writers comes with speeds locked at 2X max for ripping.
    Try http://forum.rpc1.org/dl_all.php to find a hacked firmware for your drive.
    Take a look at this thread for some tips:
    https://www.videohelp.com/forum/viewtopic.php?t=187112
