I've used SubStation Alpha a.k.a Subtitle Workshop to make some subs for some movie clips. Saved them as .srt. Imported them into DVDLab Pro and generated subtitle stream. Compiled and burned the DVD.
Now the subtitles are in really bad quality, like all pixely and stuff. Now I believe this could be since the video clips are in pretty bad quality too, the resolution is only 320x240 that for some unknow reason has been re-encoded to 480x576... Anyway, do the video resolution affect the subtitle quality? Couse when you preview the subs in the preview-window in DVDLab the subtitles look crisp and clear but the generated subtitle stream doesn't.
Just wanna know if the video size affects the quality of the subtitles and if there's any way of making them look better without changing the video resolution...?
				Results 1 to 1 of 1
  Bad quality WMV - will a conversion increase quality?By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48
  Getting bad quality with AutoGKBy alc112 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 09:37
  No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad EverythingBy koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
  Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23
  Bad quality with VobSubsBy Xavier in forum SubtitleReplies: 1Last Post: 19th Apr 2008, 03:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
