Hi
Can someone tell me what is this tool "TMPGEnc" and what does it do. I hear so much about it.I van not find any Operating Instructions. Does it do what VideoStudio does? Can you use this to capture video analogue or digital. When I open the program I see a Start button also a Video/Audio source. What do you do first. A simple explanation step by step would be appreciated.
Regards
Stelios Christofides
Firstly, please do some basic research. A quick search on the net or even playing around with the program should yield its intended function.
TMPGEnc is primarily an MPEG encoder. It has a number of other functions as well.
Regards.
Michael Tam
w: Morsels of Evidence -
Hi
TMPGEnc is mostly used to convert downloaded AVI's to VCD mpeg files (To make VCD's for your DVD player)
Video source > (Click Browse) select AVI
Audio source > (Normaly the same as above)
Output file name > Browse and type a name to save.
Load > Load a template like PAL VCD or NTSC VCD
Hit start, go for a long walk.... wait for the bing bong (Job done) now burn VCD with the mpeg it has made.
I have downloaded TMPGEnc to convert captured AVIs to MPEG for video CD recording. However I am totally stumped by this program. It has no instructions that I can find (in English anyway) and all the buttons on the program are blank with no text to give me a clue what they each do.
Does anyone have a suggestion where I can find some instructions for this program? From what I've read it is the best way to create VCDs with the best quality, but I can't seem to even get started.
Thanks -
Come on man, open your eyes, look to your left under CONVERT
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Hi Spidey
Thanks for the info. My fault that I never thought that this program comes with no operating instructions and that I could find the instructions here.
Regards
Stelios -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You downloaded the Japanese version by any chance ?, go get the English version then your buttons will display
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
