I just made several DVD-R of home movies, they play fine on my DVD hooked to my TV. I made some for other family members, Some can't play them. Is there a format I can use that will play on most if not all players, like a movie that you get from Blockbuster. What format is that?
Results 1 to 16 of 16
Robert
http://www.Money-Guides.com/ -
There is a universal standard format used. There are no other diiferent formats for dvd (well for the execption of standalone dvd recorder formats)
Most likely, the issue is media compatibility. Try different media.
However, ensure that you have a empty AUDIO_TS folder as well as the VIDEO_TS folder on the dvd.
PS... How did you make the home movies. Was it on a standalone dvd recorder or on a PC? -
Originally Posted by SCDVD
The standard should look somthing like this located within the VIDEO_TS folder:
DVD-Rs and DVD+Rs have different recording schemes - and both are different from commercial DVDs. An older DVD player may not have the programming necessary to play either of the recordable formats. If the problem persists, you could recommend that your friends upgrade their players. Since it has been around longer, a DVD-R disc will play more often in older players.
Or, like waheed suggested, your problem may be media quality. Or authoring errors - older players REQUIRE all files be in capital letters. Some older players also require the AUDIO_TS folder to be present (even tho not used).ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I have a sony dvp-s300 dvd player and according to the dvd player list it plays dvd-r better than dvd+r . I have the opposite more problems with dvd-r compatability than dvd+r. All sony dvd+r -r. Go figure.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
Gee I didn't mean to ruffle feathers.
1. I made home movies with my 8mm video cam
2. I captured the video using my all-in-wonder
3. I auther the video useing ulead (barely, i'm new to this)
4. Using ulead I wrote the video to maxell dvd -r on my internal NEC DVD recorder.
I was wondering if Movies LIKE the movies you rent from Blockbuster. Are a special format so they play on all players (see the word like, no illegal copy here)
I know some DVD players list all the formats they are compatible with, so I thought there was one type most compatible DVD+R, DVDRW, DVDR?
But your saying it's the media? Can you suggest a brand?Robert
You could try DVD+R and change the booktype to DVD-ROM. That may allow the older players to "see" the disc.
I have used Ritek and Taiyo Yuden media without any problems.Melde Melda Vessë
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
yeah, some like to just jump the gun
Have these people ever played any kind of recorded dvd media before ?
What brand did you use ?
And as i was typing this lantern beat me to it :P
I also have been using +R with the booktype changed to dvd-rom for a long time so they will be read by standalone players the same as a store bought/pressed dvd and have had less compatability issues.
But then agaon some dvd players just refuse to play any dvd recordable media. -
https://www.videohelp.com/forum/viewtopic.php?t=271418
11. How can I burn a disc like "Hollywood" does?
Discs you buy in stores are pressed metal, not burned. This process is expensive, often requiring orders of 500 or more copies of the same disc. Owning the equipment takes an investment of thounsands of dollars ($USD). For more information on the differences between pressed and burned CD/DVD media, see this video: https://www.videohelp.com/~cobra/OpticalDrivesFAQ.wmvWant my help? Ask here! (not via PM!)
I found that the ones I've used that work real well with no problem on my standalone is: verbatim digital movie (the one that looks like a movie reel) dvd+r but the -r I have had problems with taking a little longer to access and sometimes errors. I would have to open the tray close it and works fine. Also another brand that works well is the +r memorex and maxells. I have an apex as well as my sony, they work like champs in both players. Good luck rhendrix9
- Adam Savage -
- Mythbusters - -
Wow! thanks for all the responses.
I'm not confident in what I've done now. One problem is uLead Moviemaker and it's constant crashes,
and I have not quiet figured out "booktype", ulead suggests - recording format of DVD-Video for compatibility.
I'm assembling snippets from about 12 years of all the family gatherings, ulead is not handling this well, I wrote one to hard disk but when I tried to retrieve it ulead crashed, over and over!
Anyone care to suggest software?
ThanksRobert
I generally disregard brand name and look for Made in Japan on the dvd media package. Others disagree. www.digitalfaq.com has lots of info on good and bad media. Again, not everyone agrees.
Most Compatible Format for Websites
By ofpeb in forum Video Streaming DownloadingReplies: 11Last Post: 5th Dec 2011, 10:50 -
converting DVD mini disk files to compatible APPLE format- video is missing
By MovieMom in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 13:33 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 19:11 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 19:07
