i used the search button but all i got was how to burn the cue sheets...
ok heres the situation: i have a big music file and a cue sheet so wat program can i use to separate this n my comp instead of burning it>?
thnx alot
You can use a program called CD Wave Editor to split the large music file into the segments you wish to keep,if that what you mean.
Try mounting the cue file with Daemon Tools, then rip from the virtual drive the same way you would rip a CD.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Here's an even better solution:
Use EAC (Exact Audio Copy), select "Split WAV by CUE Sheet".They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
well mine is not wave it is mp3.. ne program for thats reads cue sheets? and ps i cant mount the cue shee on dtools cuz it give me a error "line 3 is sumthing blahblah"
Hiho,
you should take a look at the CUE Splitter v0.4 Beta. I guess this is exactly what you need!
Plz report your impression!
CYA Daphy
Any Video Thumbnail Sheet Makers for Macs?
By M-O in forum MacReplies: 46Last Post: 2nd Nov 2014, 10:12 -
Best Batch Processing - Video Contact Sheet Creator software?
By binar in forum Video ConversionReplies: 6Last Post: 28th May 2014, 12:09 -
How to share a Excel spread sheet online with different users
By neworldman in forum ComputerReplies: 1Last Post: 8th Oct 2010, 01:28 -
JPEG to AVI (or MPEG2) via timing cue-sheet?
By NetRodent in forum Video ConversionReplies: 0Last Post: 31st Aug 2008, 10:49 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 13:29
