    Apr 2005
    UK Washington
    Hi, sorry but I am new and need some help
    I need a firewire lead for my camcorder canon mvx250i but not sure which lead i need to buy
    please can you help ?
    thanks so much in advance
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Most likely 4 pin to 6 pin but you need to determine that. Look on the cam and your computer and compare to these pics and purchase the appropiate one.
    4 pin (probably what's on the cam):
    6 pin (probably what's on your coputer):
    If the cam only has 4 pin what you connect it to on the computer doens't matter, either 4 or 6 pin will suffice.
    Apr 2005
    UK Washington
    Hi the coalman, thanks for your reply.
    Checked camcorder looks same as your 4 pin picture (( however counted the pins entries and there are 5 ?? ))
    Computer looks like the picture of 6 pin only in 1 straight line not two lines in your pic
    hope this helps
  4. Hi
    I have the Canon MVX250i and use a 4pin to 6pin lead exactly as the coalman says.
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    That's a USB connection your looking at they are similar but the shapes are different, look at the shapes above again. They have to exactly match. In the 4 pin it would be the black area, in the six pin it would be the shape of the grey area surrounding the black.
    Look at some of these pics which are for firewire (1394,I-link): http://images.google.com/images?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-22,GGLG...firewire+4+pin
    Apr 2005
    UK Washington
    Yes shape 6 pin is on my computer, so i will buy 4 to 6 thanks alot
