Ok, this is my first attempt at ripping a dvd. I'm trying to rip Jurassic Park 3. I used SmartRipper to get the .vob files. I then use DVD2AVI to open up the .vob files. Then I click on "save project" and the program looks like its combining the .vob files to an audio file and a .d2v file. 1/4 the way through the process stops and in the Statistics window, the box that says "INFO", it says "A.E.!". What does this mean? It stops at the same point every time I try to do this.
wut settings did u use in smartripper/dvd2avi...
could be u didn't remove the multi-angles... -
I followed the directions on dvd ripping from the How To section. I don't remember the directions talking about removing the multi-angles. Can you tell me how and where I do that?
How did you rip vob files out of your dvd, movie mode or file mode? because if you rip in file mode mostlikely dvd2avi will give you an error. Try to rip again in movie mode and see if dvd2avi still give you same problem.
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
Problem saving stream (RTMP) with VLC
By one2345678nine in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Nov 2009, 10:13 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Problem with Saving Parameters in Pan/Crop.
By solarblast in forum EditingReplies: 2Last Post: 11th Jan 2008, 19:54 -
no DGIndex timestamp while saving project file
By ecc in forum DVD RippingReplies: 1Last Post: 22nd Dec 2007, 14:38
