When using TMPGEnc to convert AVI to MPEG, under Setting, Audio, then "MPEG-1 Layer II", how can I set the bit rate beyond 384 kbits/second? The pull-down menu only allows at most 384.
384kb/s is the limit. If it's not high enough, you might want to try PCM.
if DVD is your target format. If VCD/SVCD is your target, you're stuck with mp2 @ 224 kbps.Originally Posted by kush
/Mats -
Yeah - you're right! Been too long since I did any VCD/SVCD related stuff, obviously!
/Mats
How to reduce Audio Bit Rate
By mad_mackem in forum Video ConversionReplies: 6Last Post: 28th Dec 2011, 10:30 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
audio bit rate showing in video
By soulman1015 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 11:44 -
how do i know if Nero is changing my audio bit rate?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 19th Nov 2008, 16:49 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48
