well how do you burn? do you keep all the special features or you just burn the whole dvd?
Results 31 to 52 of 52
I only end up keeping the menu and the main movie. I omit the rest like special features, additional audio tracks etc...
DvdReMake will do it anyway you like it ( http://www.dimadsoft.com/dvdremake/ud_dg_01.php )
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools -
DVDRemake Pro is great, I use it all the time. Some advice on it:
-Buy from MackemX's link on the Tool page, save a few $
-Buy the Pro version to start with, you'll want it sooner or later and you save money that way.
-Only use Hide (not Delete) functions until you gain confidence in reprogramming the code.
-Always test with an RW disc or using a software player before burning.
-The guys at the DVDRemake forums are great help if you're stuck.
I always get rid of annoyances like copyright warnings, disclaimers and trailers before the menu, even if the original is single layer.
On dual layer titles I need to reduce the size of, I usually get rid of trailers for other movies, still galleries, and any features that look boring like production meetings (blah). I also always get rid of non-English audio (unless the movie is foreign-then I keep the original language too).
I keep only 1 English soundtrack, preferring the multi-channel over 2-channel since I have surround. On DTS titles I get rid of the DTS if there is also a DD5.1 track, otherwise I keep the DTS and sometimes lose the DD2.0/PCM track (NOTE this makes a non conforming DVD that won't play without a DTS decoder). If all I had was stereo or TV sound I would just keep the smallest track. I usually keep any commentaries unless they're worthless.
I usuallly keep the other features that look interesting, maybe music videos depending on whether I like the music or not. Trailers for that movie I might keep if they show scenes not in the movie, otherwise they're gone too.
I usually leave the menus alone except for hiding the buttons that don't work (foreign languages and any features I've deleted). Some people eliminate the transitions (i.e. the clips that play between menus) but I tend to leave them in.
Then I use DVDShrink to compress the menus and extras to the minimum possible size, since the extras are almost invariably talking heads and footage from the movie, quality is not important. This leaves the most space possible for the movie. -
Originally Posted by waheed
No. I use titlesetblanker first, then use dvd shrink. First, blank out all the crap, then use dvd shrink to compress and remove any additional audio streams like directors commentaries.
Originally Posted by tmac2085
Did you read anything on this site? Guides?
There is a wealth of information in the guides section to the left that will give you most of the answers you need. Seems ridiculous to me to want to be spoonfed through the process. First read, then if you have any questions... ask. Ask me personally... I don't care... make an effort to do something on your own.
If this seems out of line, I apologize. -
yeah seems to be out of line. i can write and ask anything i want.
2. I use DVDShrink to open the DVD folder and use the still picture function to replace FBI screens, etc with blank black stills or with a "Please Press Forward" if the replaced screens are more than 10 seconds total.
3. I then compress (if necessary) using DVDShrink, set to deep analysis and Sharp error correction. -
i decrypted all the files to my HD with dvd decrypter, then i took out stuff i didnt want with titlesetblanker, but now when i open the file with dvd shrink it says it failed to open the VIDEO_TS.IFO file. what did i do wrong?
Originally Posted by StarofRadiance
After removing the stuff I dont need with CloneDVD2 ... I then use DVD-Rebuilder ... 6 passes ... sometimes 9 passes ... and go to sleep.
Sometimes if I or my girlfriend is going to use the main computer ... I use my Dell 5150 with a external USB DVD Burner and an external Harddrive ... do the processing.
As soon as I finish moving from my apartment ... I will have "my main computer" over here to use. He he he ... we will practically have a computer in every corner of her [our] house. -
How did you rip the files with dvd decrypter. Ensure you rip all the files in file mode. Try rippng again, blank out with titlesetblanker, then use shrink.[/quote]
i ripped the files through file mode. used titlesetblanker to take out VTS_02*.VOB. Then went to dvd shrink and says the same exact thing. "Cannot open VIDEO_TS.IFO" And to test i click "Back to orig. files" and dvd shrink opened it fine. and then i blanked it one more time and clicked the delete backups and now it dont work at all......maybe i have to leave the previews in there huh? this is driving me NUTS
Ensure that you are not blanking out the VIDEO_TS file. In titlesetblanker, it is checked to blank out by default. Uncheck this box and then try again. You will need to rip the dvd again to start fresh.
the only thing that is checked is the VTS_03_*.VOB file. i click Blank! and then go to shrink, and it gives me the same error. i'll just burn it with the previews...unless someone has the movie Hostage and they can try to see if it works...
would there be any use of shrinking the dvd first and then blanking out stuff?
New to video stuff...
By SiNNiK in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2010, 12:41 -
PXL2000 and other lo-fi stuff
By billythecrashsxcker in forum Newbie / General discussionsReplies: 0Last Post: 28th May 2008, 12:39 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 07:52 -
removing stuff from dvds
By zookeeper525 in forum EditingReplies: 14Last Post: 1st Jan 2008, 22:07 -
menus and stuff
By zinc in forum Video ConversionReplies: 4Last Post: 8th Dec 2007, 08:51
