was just wondering what people use to take out stuff like trailers and extras. I have Vob Blanker and Title Set Blanker; but have no clue how to use them. I need some help. Thanks!
Results 1 to 30 of 52
i was also wondering if its complicated to do. Does it take awhile?
tmac
If you want movie only then DVD2One or DVD Shrink will do that.
DVD2One will take about 5 mouse clicks and about 20 minutes.
DVD Shrink takes more clicks but it's free.
Neither are complicated.
Regards,
Chas -
I usually use CloneDVD to remove unwanted extras, then DVDShrink to compress and replace unwanted menu screens. If I want to do movie only, I use Shrink alone.
Also the version of CloneDVD that I have has problems with the new encryption methods if I use it first, but if I use DVD Shrink first to decrypt, it works great. Even DVDecrypter doesn't work for me on these, but Shrink does. -
i want everything the DVD has on it but the previews before the menu comes up, and the previews that are at the menu as well. I want to keep everything but those previews. so StarofRadiance, do i shrink the dvd first with dvd shrink and then use clone dvd?
vobblanker will do what you want
find a guide on the left that uses vobblanker to find out how -
The way I do it is to play the individual vobs directly from the dvd folder on the hard drive using PowerDVD. This tells me exactly which titleset contains the movie, trailers, warnings etc...
Then I use titlesetblanker to blank out the required titleset. -
I use Shrink for movie only. I tried VobBlanker on a couple of stubborn disks, but never got useable output (PowerDVD, Shrink, IFOEdit - nothing would open it)
Read my blog here.
Originally Posted by waheed
are the VTS_01_0 through VTS_29_0 all the same? i played all the those kin of files and they play the same thing. For example, i opened VTS_01_0, and then i opened VTS_13_0, and it plays the exact same thing.
i actually got my previews out with TitleSetblanker. but do i have to check both of the ones i wont blank from the TitleSet Videos and the TitSet Menus list? For a example for the Hitch DVD how can i make it that i can't select Previews from the main menu?
29 Titlesets is alot
I usually play the VTS_XX_1.VOB file where XX can be 01, 02, 03, etc...
This can be the main movie, extras, trailers etc. Depending on which one I play. Usually, VTS_01_1.VOB is the main movie which means VTS_01_0.VOB is the menu. Hence, the rest of the titlesets is other stuff like extras, trailers, deleted scenes. If a titleset contains several vobs, its most likely the main movie.
Sometimes, VIDEO_TS.VOB contains the warnings screens (well mainly for region 2) so I blank that out as well. -
my goal is just get the previews and all the copywright crap out. and i did that. but how can you edit the main menu so no one can select another menu like Previews, or Extras?
Titlesetblanker sorts that out automatically. Play the dvd from your hard drive to test it out. Click on one of the extra features in the menu, you'll find that it does nothing.
But I yu really want to block out other menu features, You'll need to use MenuEdit, which is not a freeware. It can be used to delete menu buttons. -
I long ago stopped worrying about keeping the menus. On a couple of my backups I have the movie and the making of (making of encoded at half-D1) on the same disk with no menu. Mind you, my player allows me to see the titles ont he disk, so I can playback title or chapter without menus. Once you have played through them once, they seem to be a waste of precious space on a backup.
Read my blog here.
Originally Posted by tmac2085
if you cut out all the previews, would that help with quality of the movie?
Yes. Cutting out previews means more room for the main movie, thus requiring less compression.
Depends how long they are and how much space they take up. Often they are encoded at lower bitrates than the movie, so you might not get much back. When I backed up the three Harry Potter films for my kids, I found I could save 10 minutes from each film by cutting the end credits. That worked out at several % of extra space for the movie itself. Again, no menus. I used Shrink to reauthor and trim, but not reduce. DVD Rebuilder with CCE did that for me.
Read my blog here.
i'm about to burn, but i have VOB files with the ~ at the end. do i just select all the files like normal and burn or what?
If you have the ~ at the end, it means you used the backup feature in titlesetblanker. Open the dvd with titlesetblanker again and delete the backups.
with Titlesetblank is there anyway you can blank like VTS_02_1 since it only shows VTS_02_0 ???
VTS_02_1.VOB would be shown as VTS_02_*.VOB. You need to blank that out.
i know this doesn't make much sence but is there anyway of keeping VTS_02_0 and blanking out VTS_02_1? because VTS_02_1 is like the Paramount DVD intro i thought i would keep and VTS_02_1 is the DOWNLOADING movies is illegal and blah blah...if you can't it wont hurt me none. Thanks
DVD Shrink natively lets you insert stills now. Use that.
i'm guessing to get the clearest DVD quality you can get is to take out everything like extras and all that stuff huh?
True. It also helps to remove any additional languages such as directors commentarys and even DTS in some cases.
New to video stuff...
By SiNNiK in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2010, 12:41 -
PXL2000 and other lo-fi stuff
By billythecrashsxcker in forum Newbie / General discussionsReplies: 0Last Post: 28th May 2008, 12:39 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 07:52 -
removing stuff from dvds
By zookeeper525 in forum EditingReplies: 14Last Post: 1st Jan 2008, 22:07 -
menus and stuff
By zinc in forum Video ConversionReplies: 4Last Post: 8th Dec 2007, 08:51
