Hey ppls.. I got a couple of vob files here..and want to burn them into a dvd.. Used Nero and tried to drag them into the video_ts folder but not possible. Told me there's an error...
So how do I burn these files? Do I need to reauthor them?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Flaystus
Closed Thread
You need to create IFO and BUP files for them.
Do you want a menu ?
Do you want them to play one straight after the other ?
Do you want chapters ?
How you want the navigation determines how best to proceed
If in doubt, Google it.
Can you list the files you've got (or alternatively just take a screenshot of the opened folder) ?
Also, the error Nero gave you would be handy.If in doubt, Google it.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 05:44 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 08:52
