I am converting a movie from PAL to NTSC..I want to keep the 5.1 surround AC3 so I tried to use AC3Machine to convert the audio so that it will be in synch..here's the problem:
when I start AC3Machine, the transcoding window pops up and then goes away...I have the most updated BeSweet and AC3Machine....any suggestions on how I can get it working? Or is there another option to convert the ac3 5.1 so it is in synch with the NTSC FPS?
yes I have tried DGPulldown but it is too much of a headache....
AFAIK you have to decode your AC3
-> PAL <-> NTSC differs about ~4% in length because of their diffrent fps rate. The good old AC3Machine wonīt help you in this case at all.
Inside the latest Besweet beta (1.5b30) there is a improved version of soundtouch (1.3) -> try this one with your decoded AC3 (I canīt imagine that the process could work on AC3 compressed tracks) via GUI (0.7b8) and report back!
All files can be found on needfulthings
CYA Daphy
High-Performance machine taking 20+ Hours to Encode AC3 audio.
By Joe Hill in forum Authoring (DVD)Replies: 9Last Post: 25th Feb 2012, 10:30 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 02:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 04:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 17:33 -
AC3 ACM Decompressor audio problems.
By cactusjack310 in forum AudioReplies: 2Last Post: 16th Dec 2007, 13:13
