I'm putting this svcd on a disk with menus and stuff with dvd lab. Made the video and audio folders. I can play back the movie fine with PowerDVD, but when I try to burn with Nero, it says:
DVD-Video Files Reallocation Started
File Size is not a multiple of logical block size (2KB)
DVD-Video Files Reallocation Failed
The resulting DVD may not be playable
Not sure what to do. I tried opening all the ifos with IfoEdit and hitting Get VTS Sectors. But I don't think that did anything because still doesn't work. So far only thing I can think of doing is remaking the dvd in DVD Lab or reauthoring in DVD Shrink. Any ideas?
I opened the vts1 ifo file and went to VOB Extras, stripping all the vob ids and audio streams. Hopefully that'll work at a quicker pace.
Because I started the process on DVD Lab and estimated time remaining was like 8 hours. I think Ifoedit is faster since it just processes the files and not the video I think. -
I have only seen the "file reallocation" error in Nero when trying to split a DVD into 2 discs. What that means is that some VOB is missing but required by the split disc. If you see this error, I do NOT recommend burning the disc anyway. I tried that and the disc would not play in a standalone player.
However, it would appear from what you said that you have some kind of file creation problem. I have never used DVD-Lab, but it sounds like it didn't do something correctly in the authoring process. Stripping will work only if it gets the file size down to a multiple of the logical block size.
I have to admit that what you say just sounds odd. DVD-Lab should work correctly if you really did only what you say. -
on the reallocation error using nero, i have had this a few times while backing up discs, this was after using dvd2one, everytime i have had it i switched to dvdshrink to compress and resulting burnt disc was ok.
would like more info on this error from anyone in the know tho. Sorry for not being any help with the prob jman98, just pointing out that i too have had the same error but in different circumstances. -
Originally Posted by parman
This program is the best for reprocessing of vobs/ifo files. I was shocked that dvd shrink was going to take like.. 8-9 hours. IFOEdit got the job done in like.. 15-20 min
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 11:40 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 01:16 -
DVD File Allocation Failed
By Emeraldas in forum Newbie / General discussionsReplies: 8Last Post: 22nd Sep 2007, 08:26
