Hmm I ripped a DVD into VOBs, and was having trouble with the deinterlacing. I've figured out that these VOBs might be in PAL format, but programs I've tried like Premiere, VDubMod, VideoStudio, etc. won't touch the VOBs to give me their file info. Flask opens them, but sometimes the file info Flask configures itself to is wrong. (Flask is configuring itself to 29.97fps/720x480, yet when I deinterlace into a PAL file instead of NTSC, the deinterlacing finally looks good.)
Any suggestions on a way I can check the VOBs' pixels/framerate to know for sure?
Gspot,Avicodec or Virtualdub mpeg2 (all free) will open the file and tell you the video info
Nope...the VirtualDub MPEG-2 won't open it, and DVDtoAVI/GSpot open it but the file info comes up blank. AVIcodec gives some info but not the framerate/pixels.
I finally got ahold of the original DVD this was transferred from, and the label on the DVD says "PAL". HOWEVER, the demuxed version of the VOB is showing up as 720x480/29.97fps...is there any chance that could have changed during demuxing (though I doubt it)?
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15 -
Best way to convert NTSC .VOB --> PAL .VOB
By macuser1960 in forum ffmpegX general discussionReplies: 1Last Post: 9th Mar 2008, 17:43 -
.Vob, PAL to NTSC tool??
By i0r in forum Authoring (DVD)Replies: 6Last Post: 16th Dec 2007, 17:45 -
Convert NTSC VOB --> PAL VOB
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 12:29
Thanks... Worked like a charm?
