this has just happened recently and i cant seem to fix it, when ever i try to reduce the hight of a file when encoding it using main concept then i get the following results
however if i frame serve the exact same file from virtual dub mod then i can scale it (using main concept scale menu) and there are no problems at all
it only does this weird colour blocks thing when i try to encode and scale directly within main concept
encoding the file with no scaling works fine
any ideas .... please
I would suggest MC is having a problem with the codec required to view and manipulate this file. Virtualdub does not have this problem, and frameserving to MC gives MC an uncompressed source to work with. You can continue to frameserve and ignore the problem, or spend time trying to isolate MC's problem. It might be as simple as updating the codec. However, you also have a working solution if you can't solve the MC issue.
Read my blog here.
Creative Media Format (.CMV) proof-of-concept encoder
By plexx in forum ProgrammingReplies: 8Last Post: 15th Jul 2011, 16:13 -
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
