Help me please! I have 2 AVI files that i need combine into one MPG file or one dvd file. Both AVI files are part A & B of each other.
Need to know what is the best and the quickest software to have this done?
Thanks to anyone who took the time to read and/or respond to my post.
Join with virtual dub.Then use dvd2svcd (www.doom9.org)use with cinema craft encoder or TMPGEnc (SVCD VCD DVD)output then use TMPGEnc DVD Author 1.6" to make chapter and files and then it burns it for you(DVD)..
This is the best youll get i think or you may try
svcd2dvd (www.svcd2dvd.com) You just put in your 2 AVI OR xvid ,away you go convert to a nice 4.37gb dvd,this will also burn it and make a simple menu if you want one,NEEDS NET FRAMEWORK THOUGH(free)You can convert up to 2gb for nought .It will convert svcd vcd avi divx easily.Hope this helps a little.. :P
Stay away from them b******* encoders such as NERO and all the other crap ones too many too mention...
mkv to avi with xvid4psp! It's killing me! Help pls!
By Ramazan in forum Video ConversionReplies: 1Last Post: 28th Sep 2011, 08:52 -
Need a *good* software for converting MP4 to AVI ..
By ahmadka in forum Video ConversionReplies: 6Last Post: 24th Nov 2010, 16:44 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 17:04 -
What software is good for converting to DivX..?
By Karel Bata in forum Video ConversionReplies: 6Last Post: 8th Dec 2009, 13:36 -
looking for a good software to merge files....
By XDPD7 in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 13:20
