i have a video with a VBR heading.
i know how to rip the audio/video stream and reinterleave them, but this particular movie is giving me problems.
whenever i pull the audio stream with VDM i end up with a track that is roughly 300 megs and 28 minutes long...
i have tried full process, direct stream, and reencode on the fly.. still doesnt go past 28 minutes.
why is it not demuxing the enitire stream?
the audio is there, as i have watched the movie.. VDM just stops demuxing after the 27 minutes.
did i check some box on accident?
what gives?
computer sciences
first, i want to say thank you on the numerous tutorials you have provided.
they are the basis for my authoring skills, and for a good bit i think i had every baldrick post indexed.. they have been on point...
and your solution to this went of absolutely flawless... i used Ace-High to convert to a .wav and it interleaved without a hitch.
thanks for the quick and accurate reply!computer sciences
Using GraphEdit to properly stream with the Hauppauge HD PVR
By Burbruee in forum Video Streaming DownloadingReplies: 7Last Post: 26th Apr 2011, 15:17 -
any reason this wont stream on xbox360
By carlos28355 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2009, 22:17 -
Got ripbot working, BUT it wont stream to my PS3
By Fiostech in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2009, 13:15 -
Demux mpeg-2 stream from avi container
By niko84 in forum EditingReplies: 7Last Post: 6th Oct 2007, 01:43 -
WMP11 wont stream
By wayneyg in forum Newbie / General discussionsReplies: 18Last Post: 2nd Jun 2007, 04:09
