Can I edit a DVD recorded on a DVD recorder?
Erm... it might seem a dumb thing to ask...
But a while back, we bought a Lite On DVD recorder.
It records OK.
But... we can't access the recorded DVD's on PC.
We never got round to changing it asking for tech help.
Are there any specific models that are more PC compaitble?
In particular, I'm thinking of buying the following model:
"H & B DRX-430 Slimline DivX DVD Recorder"
I haven't found much feedback on this website.
Any further opinions would be appreciated.
Thanks.
Jam
Results 1 to 9 of 9
Is the DVD finalized? It can't be accesed outside the recorder until it is...
/Mats -
aaah... that maybe would explain y my liton won't work.
so is there a function to finalise on every dvd recorder?? -
Originally Posted by jammer20002
If you want to edit, rewriteables are the best. You can start early and end late to make sure you got it all and then trim it in the computer.
Nyah Levi -
Originally Posted by nelson133
/Mats -
Sometimes, even after its finalized the DVD volume created by the SETTOP recorder will appear in EXPLORER as 4 gig or so of material, but upon investigation, only one .VOB with file weight (typical .99gb)
if this ids the case, copying the VOLUME to the PC's harddrive will not work!
PLEASE use decrypter, and a normal VOLUME structur will be evident when finished ripping (several .VOB's bearing the 4.~gb file sizes)
Appreciate HELP: Unfinalized DVD+Rs recorded on LG RH 177S (DVD Recorder)
By mozzieland in forum DVD RippingReplies: 8Last Post: 14th Feb 2009, 08:27 -
i recorded a show from my dvr to my dvd recorder
By billrhonda in forum Newbie / General discussionsReplies: 4Last Post: 6th Jan 2009, 10:48 -
How do I edit and reauthor a recorded DVD on my computer?
By Baldrick in forum DVD & Blu-ray RecordersReplies: 3Last Post: 17th Nov 2008, 09:03 -
Difficulting with dvd recorded on a LG dvd recorder
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2008, 10:45 -
Editing recorded material made by DVD recorder
By sallywil in forum EditingReplies: 2Last Post: 26th Aug 2007, 19:58
