i bought a psp the other day and i wanted to get some off my dvd's onto it, i decided that i need to convert them at high qualtiy to mpeg 2 with either ac3 soundtrack or 192 vbr mp3. then i would convert them to mpeg4 for the psp. what program could i use? thanks
The program you are looking for is PSP Video 9. It is in the tools section along with a very good user's guide. There are naming conventions that you must observe when putting a movie on the memory card. Also you must have at least a 512 mb Duo Pro memory stick.
HolmesEliminate the impossible. Whatever remains, no matter how improbable must be the answer.
S. Holmes -
3GPConverter also has a PSP template (it uses XivD for the video encoding, and QT for the muxing, i think).
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 11:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 09:27 -
PSP video 9 - 0 KB file
By bboypkj in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 15:34 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 15:13
