Results 1 to 9 of 9
  1. I burnt audio dvd with audio dvd creator which took five hours.and all it shows in my computer and dvd player (MHC zx70)is C:13:00 error.
    Please help
  2. I did and it says this error is about to clean your disc.
    But my player is playing other disc properly and another thing in computer the properties of disc shows the disc is full but the size is 0 bytes.
  3. Take the disc and try it on another player and pc.
  4. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    does it play in your computer
  5. no success
  6. Member Sifaga's Avatar
    Aug 2003
    do you still have the files on your computer (VIDEO_TS Folder)
    can you play the files off your computer ?
    if not then your doing something wrong in audio dvd creator
  7. I did not burnt them on hard disk instead mark the option of burning on dvd directly.
  8. Member Sifaga's Avatar
    Aug 2003
    you should make sure it works on your harddrive before you burn to a disc
