I bought a VHS movie from the store. When my vcr plays it I get bands of lines through the video. It does the same in my daughters vcr as well. It is definitely the tape. I tried adjusting the spindles but that just adds lines over top of whats there.
I do notice while playing the video, if you forward cue the lines clear up somewhat. It's almost like the tracking being off. Is there any way to adjust my vcr to get it to play the video, at least to copy it to a good tape?
Thanks.
PS. I have a 1995 Orion 4 head vcr.
cooljoe666,
You could probably align the tape guides to play the movie but that would screw up all the other tapes you play.
I suspect the tape is recorded in SLP which is critical to tape path alignment. If so, take it back and try again or get a refund.
Chas -
Hi,
I cannot return the tape because I bought it many miles from home. The tape is in SP mode. The picture is clear and the audio is perfect except it looks like the tracking is way off. -
cooljoe666
If it is truly a tracking problem then the only thing you can do is to misalign your vcr to the vcr that recorded it.
If you wish to do this, loosen the set screws, not too loose, that lock the takeup and suply guides that wrap the tape half way around the heads.
If you have an oscilloscope then conecect it to the envolpe test point and while the tape is running, adjust the guides for a flat response. When done, lock the set screws.
With out an Oscope then while playing, watch the pic and adjust the guides for best pic. Then lock to screws.
Of course you will have to realign the guides to a good standard tape. Usually a standard commercial tape will do.
Other than that, no hope.
Regards,
Chas -
If you're talking about the two things that pull the tape around the head, I turned those while the tape was playing. It basically added more lines but never fixed the present ones. It took awhile to get it back to normal though. I wonder what else it could be?
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 16:17 -
How do you like your pizza? Fresh, frozen, store bought, home made?
By yoda313 in forum PollsReplies: 65Last Post: 24th Dec 2009, 08:32 -
Store bought DVD movies rarely play
By Mark Girvan in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2008, 13:12 -
Trying to rip scenes from a store bought DVD...no dice
By Huntr777 in forum MacReplies: 2Last Post: 4th Nov 2007, 07:14 -
scenes missing from store-bought movies
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 15:53
